Hey everyone,
Just a heads up: I made a quick plugin for viewing nomnoml code in a HTML preview: nomnoml | Drafts Directory
Any code in a nomnoml fenced block gets transformed. Hopefully you guys find it useful!
Hey everyone,
Know some other users have mentioned nomnoml in the past: Simple Graphing Library with nice look and online features
Looks nice. Can you get it to render to a graphic in data: URI form? Then it could be inline in a draft.
It’s a good question. I bet that canvas.toDataURL() could be used on each nomnoml drawing — but don’t think I’m proficient enough at Drafts Scripting yet for passing it back to the original text?
After reading through the Advanced HTML Previews documentation:
data: image is certainly doable for a single nomnoml code blockHere’s what I currently have running in a separate test action:
great stuff. I am still planing to integrate the new feature to make nodes inside nomnoml clickable.
it is based on my request at https://github.com/skanaar/nomnoml/issues/121
if you have a github account lets join forces.
@martinpacker
the tool mdpre could integrate nomnoml graph generation as an upcoming feature
Yes: We’d have to find a suitable semantic for it. =nomnoml and =endnomnoml as a bracket round the lines with the actual diagram?
BTW, not to promise anything but in md2pptx I’m investigating whether we could support data: URI graphics. That way you could include them inline in Drafts - if it supported them. (Transclusion with mdpre might be the best way of managing them.)
By the way, my filterCSV project turns iThoughts CSV-encoded trees into DiGraphs - with .dot language. It might be able to generate nomnoml.
(It does lots of other things besides, but these probably aren’t relevant here.)
I am having trouble to set it up
fenced block should be
some text
```nomnoml
[some] - [awesome]
[awesome] - [diagram]
more text
But the diagram does not get converted in the preview
Any help?
I gave this a quick go with the action posted above.
It gave me this preview.
Which looks right to me at first glance.
Any chance you are using a different or modified action?
What is the HTML output you get?
strange.
it is not working on my side…
i have to check this (urls to scripts…)
Hey @Andreas_Haberle ,
I could see how my screenshots could lead to some confusion.
The current action displays nomnoml in a HTML preview.
Based on @martinpacker’s idea of inline data: base64 PNG, I had been prototyping an additional nomnoml action (but haven’t released that one yet).
You’re making me hurry up with the idea of supporting data: URIs for graphics in md2pptx.
I am not surexit did.
What was my misunderstanding?
I feel an action to 1) take selected text and render it this way and 2) create a md2pptx graphics slide coming on. I guess I’m being offered the first part of this.
I guess the thing I did with the links should easily be added via extending @zach action … my weekend gets busy
This is the next iteration
It uses the nomnoml-svg version and clickable links…
I have a working version in a html file (chrome and safari) if anyone is interested in experimenting further on that road.
I am not quite happy about some things:
window.open( url ) seems not be working inside the preview neither on macOS nor on iOSalert( ... ) even seems to crash/freeze the preview on macOSSo I think I have to read deeper inside some documentations (Drafts Script API and Documentation …)
Investigate more …
One done - three more to go …
[Discussion] draft.setTemplateTag( tagName, tagString); // 2.Parameter is String!
Did you publish a test source file?
this would be the action for now:
newline around the link make it more visible (it was referenced in context of the paragraph of my previous post)
yesterday I sacrifices some sleep to:
HTML PreviewHTML Preview (borowserly and DOMParser)… in this sense it is more like a second automation engine than simple HTML viewer (I could have already guessed it after learning about this nice list input GUI in Drafts last week)
