I was working on a action yesterday and could not find why my template would crash on using my custom template tag set with draft.setTemplateTag( tagName, tagString);
From @zach script I had a nice code template that set a float value in the template.
Nice!
A quick copy and my dictionary/object was stored in the value.
Buut - the HTMLPreview would not work if I used this custom template with [[tagName]]
24h later I was reading the documentation and found the problem.
the second parameter is string only !
Why?
- Java Script converts the float to a string
- Java Script does NOT convert an object to string
This would need a JSON.stringify( tagString ) and do not forget the JSON.parse( draft.getTemplateTag( tagName ) for back conversion.
My fiddled code snippet to solve it in futureā¦
Code - read close before consumption
require("tad.js");
class TagsDatabase {
constructor( p_debug ) {
this.debug = p_debug;
store( p_tagName, p_value )
let r_done = false;
let tagData = JSON.stringify( p_value );
p_tagName, tagData);
let jsonString = draft.getTemplateTag( p_tagName );
let value = JSON.parse( jsonString );
r_done = ( jsonString == tagData );
//if(this.p_debug)
app.TA_msgInfo("done: " + r_done +
"\ntagName: " + p_tagName +
"\nvalue: " + JSON.stringify(value) );
return r_done;
restore( p_tagName )
let r_value = JSON.parse( jsonString );
//if(this.p_debug)
app.TA_msgInfo(
"tagName: " + p_tagName +
"\nvalue: " + JSON.stringify(r_value) );
return r_value;
tags = new TagsDatabase( true );
tags.store( "a", {"b": 13} );
tags.restore( "a" );
Do not let Java Script fool you. ![]()
Andreas
