I am new to Drafts. I want to create a PDF from a document in Drafts. Is that possible? If so how? I have looked through Help and cannot find.
A quick search on this forum should have given you several options.
Anything you can print, can be saved as a PDF on iOS or Mac. On the Mac, there is a drop down in the print dialog, on iOS, it’s a bit more obscure.
Drafts ships with several print actions that can used with this functionality.
