I’ve just updated my Things Parser to version 3 in the action directory. I’ve decided to move from the old custom syntax to TaskPaper to take advantage of the syntax highlighting in Drafts and to aid compatibility with other apps.
If you’ve never used Things Parser before, it takes tasks written in the TaskPaper format and imports them into the Things app. It supports everything that Things itself does including checklists, headings, natural language dates and more. You can read more about the details in my blog post.
In addition, to this, it also allows the use of template variables using the Mustache Prompt system, which you can read about in this blog post.
