Hello,
Is there an action that can summarize the number of drafts by syntax? Something similar to this one for summary and tag counts.
Hello,
The latest version of the ThoughtAsylum - Power User action group’s TAD-Display Drafts Counts action now includes a section that breaks down the count by syntax.
For info, the summary report it produces has tables of counts in the following:
Hi! I tried to run this action, but I only get name of the sections. I assume there should be a table, but VoiceOver says “1 Columns, 0 Rows”. For testing purposes, I copied results as HTML and previewed with Marked 2 and there was numbers and stats.
So action works, just not displays any information for VoiceOver.
There are several tables all in a standard HTML formatted output. Copying the HTML should just be copying what I generate in the Action.
If you are getting the results back okay as rendered HTML from Marked 2, I think that suggests an issue with the preview window.
Very late with this reply, but thank you @sylumer. The aforementioned action answers my question.
The ThoughtAsylum Action Group looks powerful–and intimidating. Respect for the time you spent building it for your needs, maintaining, and sharing here.
