I don’t know whether it would be feasible to use things like Moment – I’m just bringing in my own library of generic functions, essentially those listed below – and modelled on the Haskell Prelude – tho for Drafts I filter out all of SystemIO file functions – of which only readFile and writeFile can be written in terms of the Drafts 5 FileManager object.
(The rest of the file-related functions I use on macOS through JXA $.NSFileManager)
Composing things from a library of generics lets me click things together (and rearrange them) quite rapidly, without having to reinvent wheels, remember how to do things, or write much new code. (I have a parallel set of functions for AppleScript, tho I use that less, these days)
EQ :: Ordering
GT :: Ordering
Just :: a -> Just a
LT :: Ordering
Left :: a -> Either a b
Node :: a -> [Tree a] -> Tree a
Nothing :: () -> Nothing
Ordering :: Int -> Ordering
Ratio :: Int -> Int -> Ratio
Right :: b -> Either a b
Tuple (,) :: a -> b -> (a, b)
TupleN :: a -> b ... -> (a, b ... )
abs :: Num -> Num
all :: (a -> Bool) -> [a] -> Bool
and :: [Bool] -> Bool
any :: (a -> Bool) -> [a] -> Bool
ap (<*>) :: Monad m => m (a -> b) -> m a -> m b
apLR (<*>) :: Either e (a -> b) -> Either e a -> Either e b
apList (<*>) :: [(a -> b)] -> [a] -> [b]
apMaybe (<*>) :: Maybe (a -> b) -> Maybe a -> Maybe b
apTuple (<*>) :: Monoid m => (m, (a -> b)) -> (m, a) -> (m, b)
append (++) :: [a] -> [a] -> [a]
appendFile :: FilePath -> String -> IO Bool
appendFileMay :: FilePath -> String -> Maybe IO FilePath
apply ($) :: (a -> b) -> a -> b
approxRatio :: Real -> Real -> Ratio
argvLength :: Function -> Int
assocs :: Map k a -> [(k, a)]
bind (>>=) :: Monad m => m a -> (a -> m b) -> m b
bindLR (>>=) :: Either a -> (a -> Either b) -> Either b
bindList (>>=) :: [a] -> (a -> [b]) -> [b]
bindMay (>>=) :: Maybe a -> (a -> Maybe b) -> Maybe b
bindTuple (>>=) :: Monoid a => (a, a) -> (a -> (a, b)) -> (a, b)
break :: (a -> Bool) -> [a] -> ([a], [a])
breakOn :: String -> String -> (String, String)
breakOnAll :: String -> String -> [(String, String)]
breakOnMay :: String -> String -> Maybe (String, String)
cartesianProduct :: [a] -> [b] -> [(a, b)]
caseOf :: [(a -> Bool, b)] -> b -> a -> b
catMaybes :: [Maybe a] -> [a]
ceiling :: Num -> Int
center :: Int -> Char -> String -> String
chars :: String -> [Char]
chr :: Int -> Char
chunksOf :: Int -> [a] -> [[a]]
compare :: a -> a -> Ordering
comparing :: (a -> b) -> (a -> a -> Ordering)
compose :: (b -> c) -> (a -> b) -> a -> c
composeListLR :: [(a -> a)] -> (a -> a)
composeListRL :: [(a -> a)] -> (a -> a)
concat :: [[a]] -> [a]
concatMap :: (a -> [b]) -> [a] -> [b]
cons :: a -> [a] -> [a]
const_ :: a -> b -> a
createDirectoryIfMissingMay :: Bool -> FilePath -> Maybe IO ()
curry :: ((a, b) -> c) -> a -> b -> c
curry2 :: ((a, b) -> c) -> a -> b -> c
delete :: Eq a => a -> [a] -> [a]
deleteAt :: Int -> [a] -> [a]
deleteBy :: (a -> a -> Bool) -> a -> [a] -> [a]
deleteFirst :: a -> [a] -> [a]
deleteFirstsBy :: (a -> a -> Bool) -> [a] -> [a] -> [a]
deleteMap :: k -> Dict -> Dict
difference (\\) :: Eq a => [a] -> [a] -> [a]
div :: Int -> Int -> Int
doesDirectoryExist :: FilePath -> IO Bool
doesFileExist :: FilePath -> IO Bool
doesPathExist :: FilePath -> IO Bool
draw :: Tree String -> [String]
drawForest :: Forest String -> String
drawTree :: Tree String -> String
drop :: Int -> [a] -> [a]
dropAround :: (Char -> Bool) -> String -> String
dropFileName :: FilePath -> FilePath
dropWhile :: (a -> Bool) -> [a] -> [a]
dropWhileEnd :: (Char -> Bool) -> String -> String
either :: (a -> c) -> (b -> c) -> Either a b -> c
elem :: Eq a => a -> [a] -> Bool
elemAtMay :: Int -> Dict -> Maybe (String, a)
elemIndex :: Eq a => a -> [a] -> Maybe Int
elemIndices :: Eq a => a -> [a] -> [Int]
elems :: Dict -> [a]
enumFromThenTo :: Enum a => a -> a -> a -> [a]
enumFromThenToChar :: Char -> Char -> Char -> [Char]
enumFromThenToInt :: Int -> Int -> Int -> [Int]
enumFromTo :: Enum a => a -> a -> [a]
enumFromToChar :: Char -> Char -> [Char]
enumFromToInt :: Int -> Int -> [Int]
eq (==) :: Eq a => a -> a -> Bool
evalJSMay :: String -> Maybe a
even :: Int -> Bool
exp :: Float -> Float
fanArrow (&&&) :: (a -> b) -> (a -> c) -> (a -> (b, c))
filePath :: String -> FilePath
fileSize :: FilePath -> Either String Int
fileStatus :: FilePath -> Either String Dict
filter :: (a -> Bool) -> [a] -> [a]
find :: (a -> Bool) -> [a] -> Maybe a
findIndex :: (a -> Bool) -> [a] -> Maybe Int
findIndexR :: (a -> Bool) -> [a] -> Maybe Int
findIndices :: (a -> Bool) -> [a] -> [Int]
firstArrow :: (a -> b) -> ((a, c) -> (b, c))
flatten :: NestedList a -> [a]
flip :: (a -> b -> c) -> b -> a -> c
floor :: Num -> Int
fmap (<$>) :: Functor f => (a -> b) -> f a -> f b
fmapLR (<$>) :: (a -> b) -> Either a a -> Either a b
fmapMay (<$>) :: (a -> b) -> Maybe a -> Maybe b
fmapTree :: (a -> b) -> Tree a -> Tree b
fmapTuple (<$>) :: (a -> b) -> (a, a) -> (a, b)
foldMapTree :: Monoid m => (a -> m) -> Tree a -> m
foldTree :: (a -> [b] -> b) -> Tree a -> b
foldl :: (a -> b -> a) -> a -> [b] -> a
foldl1 :: (a -> a -> a) -> [a] -> a
foldl1May :: (a -> a -> a) -> [a] -> Maybe a
foldlTree :: (b -> a -> b) -> b -> Tree a -> b
foldr :: (a -> b -> b) -> b -> [a] -> b
foldr1 :: (a -> a -> a) -> [a] -> a
foldr1May :: (a -> a -> a) -> [a] -> Maybe a
fromEnum :: Enum a => a -> Int
fromLeft :: a -> Either a b -> a
fromMaybe :: a -> Maybe a -> a
fromRight :: b -> Either a b -> b
fst :: (a, b) -> a
gcd :: Int -> Int -> Int
genericIndexMay :: [a] -> Int -> Maybe a
getCurrentDirectory :: IO FilePath
getDirectoryContents :: FilePath -> IO [FilePath]
getFinderDirectory :: IO FilePath
getHomeDirectory :: IO FilePath
getTemporaryDirectory :: IO FilePath
group :: Eq a => [a] -> [[a]]
groupBy :: (a -> a -> Bool) -> [a] -> [[a]]
groupSortOn :: Ord b => (a -> b) -> [a] -> [a]
head :: [a] -> a
headMay :: [a] -> Maybe a
id :: a -> a
indented :: String -> String -> String
index (!!) :: [a] -> Int -> a
init :: [a] -> [a]
initMay :: [a] -> Maybe [a]
inits :: [a] -> [[a]]
insert :: Ord a => a -> [a] -> [a]
insertBy :: (a -> a -> Ordering) -> a -> [a] -> [a]
insertMap :: Dict -> String -> a -> Dict
intToDigit :: Int -> Char
intercalate :: [a] -> [[a]] -> [a]
intercalateS :: String -> [String] -> String
intersect :: (Eq a) => [a] -> [a] -> [a]
intersectBy :: (a -> a -> Bool) -> [a] -> [a] -> [a]
intersectionBy:: (a -> a -> Bool) -> [[a]] -> [a]
intersperse :: Char -> String -> String
isAlpha::Char - > Bool
isChar :: a -> Bool
isDigit :: Char -> Bool
isInfixOf :: Eq a => [a] -> [a] -> Bool
isLeft :: Either a b -> Bool
isLower :: Char -> Bool
isMaybe :: a -> Bool
isNull :: [a] -> Bool
isPrefixOf :: [a] -> [a] -> Bool
isRight :: Either a b -> Bool
isSortedBy :: (a -> a -> Bool) -> [a] -> Bool
isSpace :: Char -> Bool
isSubsequenceOf :: Eq a => [a] -> [a] -> Bool
isSuffixOf :: Eq a => [a] -> [a] -> Bool
isUpper :: Char -> Bool
iso8601Local :: Date -> String
iterateUntil :: (a -> Bool) -> (a -> a) -> a -> [a]
jsonLog :: a -> IO ()
justifyLeft :: Int -> Char -> String -> String
justifyRight :: Int -> Char -> String -> String
keys :: Dict -> [String]
kleisliCompose (>=>) :: Monad m => (a -> m b) -> (b -> m c) -> (a -> m c)
last :: [a] -> a
lastMay :: [a] -> Maybe a
lcm :: Int -> Int -> Int
lefts :: [Either a b] -> [a]
length :: [a] -> Int
levelNodes :: Tree a -> [[Tree a]]
levels :: Tree a -> [[a]]
liftA2 :: Applicative f => (a -> b -> c) -> f a -> f b -> f c
liftA2LR :: (a -> b -> c) -> Either d a -> Either d b -> Either d c
liftA2List :: (a -> b -> c) -> [a] -> [b] -> [c]
liftA2Maybe :: (a -> b -> c) -> Maybe a -> Maybe b -> Maybe c
liftA2Tuple :: Monoid m => (a -> b -> c) -> (m, a) -> (m, b) -> (m, c)
liftM2 :: (a -> b -> c) -> [a] -> [b] -> [c]
liftMmay :: (a -> b) -> (Maybe a -> Maybe b)
lines :: String -> [String]
listDirectory :: FilePath -> [FilePath]
listFromTuple (a, a ...) -> [a]
listToMaybe :: [a] -> Maybe a
log :: Float -> Float
lookup :: Eq a => a -> Container -> Maybe b
lookupDict :: a -> Dict -> Maybe b
lookupTuples :: Eq a => a -> [(a, b)] -> Maybe b
mReturn :: First-class m => (a -> b) -> m (a -> b)
map :: (a -> b) -> [a] -> [b]
mapAccumL :: (acc -> x -> (acc, y)) -> acc -> [x] -> (acc, [y])
mapAccumL_Tree :: (acc -> x -> (acc, y)) -> acc -> Tree -> (acc, Tree)
mapAccumR :: (acc -> x -> (acc, y)) -> acc -> [x] -> (acc, [y])
mapFromList :: [(k, v)] -> Dict
mapKeys :: (Key -> Key) -> IntMap a -> IntMap a
mapMaybe :: (a -> Maybe b) -> [a] -> [b]
mappend (<>) :: Monoid a => a -> a -> a
mappendComparing :: [((a -> b), Bool)] -> (a -> a -> Ordering)
mappendMaybe (<>) :: Maybe a -> Maybe a -> Maybe a
mappendOrdering (<>) :: Ordering -> Ordering -> Ordering
mappendTuple (<>) :: (a, b) -> (a, b) -> (a, b)
max :: Ord a => a -> a -> a
maximum :: Ord a => [a] -> a
maximumBy :: (a -> a -> Ordering) -> [a] -> a
maximumByMay :: (a -> a -> Ordering) -> [a] -> Maybe a
maximumMay :: Ord a => [a] -> Maybe a
maybe :: b -> (a -> b) -> Maybe a -> b
maybeToList :: Maybe a -> [a]
mean :: [Num] -> Num
member :: Key -> Dict -> Bool
min :: Ord a => a -> a -> a
minimum :: Ord a => [a] -> a
minimumBy :: (a -> a -> Ordering) -> [a] -> a
minimumByMay :: (a -> a -> Ordering) -> [a] -> Maybe a
minimumMay :: [a] -> Maybe a
mod :: Int -> Int -> Int
negate :: Num -> Num
newUUID :: () -> IO UUID String
not :: Bool -> Bool
notElem :: Eq a => a -> [a] -> Bool
nub :: [a] -> [a]
nubBy :: (a -> a -> Bool) -> [a] -> [a]
odd :: Int -> Bool
on :: (b -> b -> c) -> (a -> b) -> a -> a -> c
or :: [Bool] -> Bool
ord :: Char -> Int
outdented :: String -> String
partition :: (a -> Bool) -> [a] -> ([a], [a])
partitionEithers :: [Either a b] -> ([a], [b])
permutations :: [a] -> [[a]]
permutationsWithRepetition :: Int -> [a] -> [[a]]
pi :: Float
plus :: Num -> Num -> Num
pred :: Enum a => a -> a
product :: [Num] -> Num
properFraction :: Real -> (Int, Real)
pureLR :: a -> Either e a
pureList :: a -> [a]
pureMay :: a -> Maybe a
pureT :: f a -> (a -> f a)
pureTree :: a -> Tree a
pureTuple :: a -> (a, a)
quickSort :: (Ord a) => [a] -> [a]
quickSortBy :: (a -> a -> Ordering) -> [a] -> [a]
quot :: Int -> Int -> Int
quotRem :: Int -> Int -> (Int, Int)
raise :: Num -> Int -> Num
randomRInt :: Int -> Int -> Int
range :: Ix a => (a, a) -> [a]
read :: Read a => String -> a
readFile :: FilePath -> IO String
readFileMay :: FilePath -> Maybe String
readJSON :: String -> a
readJSONLR :: Read a => String -> Either String a
readMay :: Read a => String -> Maybe a
recip :: Num -> Num
recipMay :: Num -> Maybe Num
regexMatches :: String -> String -> [[String]]
rem :: Int -> Int -> Int
removeFile :: FilePath -> Either String String
replace :: String -> String -> String -> String
replicate :: Int -> a -> [a]
replicateM :: Int -> [a] -> [[a]]
replicateString :: Int -> String -> String
reverse :: [a] -> [a]
rights :: [Either a b] -> [b]
rotate :: Int -> [a] -> [a]
round :: a -> Int
safeMay :: (a -> Bool) -> (a -> b) -> Maybe b
scanl :: (b -> a -> b) -> b -> [a] -> [b]
scanl1 :: (a -> a -> a) -> [a] -> [a]
scanr :: (b -> a -> b) -> b -> [a] -> [b]
scanr1 :: (a -> a -> a) -> [a] -> [a]
secondArrow :: (a -> b) -> ((c, a) -> (c, b))
sequenceAList :: Applicative f => [f a] -> f [a]
setCurrentDirectory :: String -> IO ()
show :: a -> String
showBinary :: Int -> String
showDate :: Date -> String
showDict :: Dict -> String
showHex :: Int -> String
showIntAtBase :: Int -> (Int -> Char) -> Int -> String -> String
showJSON :: a -> String
showLR :: Either a b -> String
showList :: [a] -> String
showLog :: a -> IO ()
showMaybe :: Maybe a -> String
showOrdering :: Ordering -> String
showRatio :: Ratio -> String
showTuple :: Tuple -> String
showTuple3 :: Tuple3 -> String
showTuple4 :: Tuple4 -> String
showUndefined :: () -> String
signum :: Num -> Num
snd :: (a, b) -> b
snoc :: [a] -> a -> [a]
sort :: Ord a => [a] -> [a]
sortBy :: (a -> a -> Ordering) -> [a] -> [a]
sortOn :: Ord b => (a -> b) -> [a] -> [a]
span :: (a -> Bool) -> [a] -> ([a],[a])
splitArrow (***) :: (a -> b) -> (c -> d) -> ((a, c) -> (b, d))
splitAt :: Int -> [a] -> ([a],[a])
splitBy :: (a -> a -> Bool) -> [a] -> [[a]]
splitEvery :: Int -> [a] -> [[a]]
splitFileName :: FilePath -> (String, String)
splitOn :: String -> String -> [String]
splitRegex :: Regex -> String -> [String]
sqrt :: Num -> Num
sqrtMay :: Num -> Maybe Num
strip :: String -> String
stripEnd :: String -> String
stripPrefix :: Eq a => [a] -> [a] -> Maybe [a]
stripStart :: String -> String
subsequences :: [a] -> [[a]]
subtract :: Num -> Num -> Num
succ :: Enum a => a -> a
sum :: [Num] -> Num
swap :: (a, b) -> (b, a)
tail :: [a] -> [a]
tailMay :: [a] -> Maybe [a]
tails :: [a] -> [[a]]
take :: Int -> [a] -> [a]
takeAround :: (a -> Bool) -> [a] -> [a]
takeBaseName :: FilePath -> String
takeCycle :: Int -> [a] -> [a]
takeDirectory :: FilePath -> FilePath
takeDropCycle :: Int -> [a] -> [a]
takeExtension :: FilePath -> String
takeFileName :: FilePath -> FilePath
takeIterate :: Int -> (a -> a) -> a -> [a]
takeWhile :: (a -> Bool) -> [a] -> [a]
takeWhileR :: (a -> Bool) -> [a] -> [a]
tempFilePath :: String -> IO FilePath
then (>>) :: Monad m => m a -> m b -> m b
thenIO (>>) :: IO a -> IO b -> IO b
thenList (>>) :: [a] -> [b] -> [b]
thenMay (>>) :: Maybe a -> Maybe b -> Maybe b
toInitialCaps :: String -> String
toListTree :: Tree a -> [a]
toLower :: String -> String
toRatio :: Real -> Ratio
toSentence :: String -> String
toTitle :: String -> String
toUpper :: String -> String
transpose :: [[a]] -> [[a]]
traverseList :: (Applicative f) => (a -> f b) -> [a] -> f (t b)
treeLeaves :: Node -> [Node]
truncate :: Num -> Int
tupleFromArray [a] -> (a, a ...)
typeName :: a -> String
unQuoted :: String -> String
uncons :: [a] -> Maybe (a, [a])
uncurry :: (a -> b -> c) -> ((a, b) -> c)
unfoldForest :: (b -> (a, [b])) -> [b] -> Forest
unfoldTree :: (b -> (a, [b])) -> b -> Tree a
unfoldl :: (b -> Maybe (a, b)) -> b -> [a]
unfoldr :: (b -> Maybe (a, b)) -> b -> [a]
union :: [a] -> [a] -> [a]
unionBy :: (a -> a -> Bool) -> [a] -> [a] -> [a]
unlines :: [String] -> String
unsnoc :: [a] -> Maybe ([a], a)
until :: (a -> Bool) -> (a -> a) -> a -> a
unwords :: [String] -> String
unwrap :: NSObject -> a
unzip :: [(a,b)] -> ([a],[b])
unzip3 :: [(a,b,c)] -> ([a],[b],[c])
unzip4 :: [(a,b,c,d)] -> ([a],[b],[c],[d])
variance :: [Num] -> Num
words :: String -> [String]
wrap :: a -> NSObject
writeFile :: FilePath -> String -> IO ()
writeFileMay :: FilePath -> String -> Maybe FilePath
writeTempFile :: String -> String -> IO FilePath
zip :: [a] -> [b] -> [(a, b)]
zip3 :: [a] -> [b] -> [c] -> [(a, b, c)]
zip4 :: [a] -> [b] -> [c] -> [d] -> [(a, b, c, d)]
zipWith :: (a -> b -> c) -> [a] -> [b] -> [c]
zipWith3 :: (a -> b -> c -> d) -> [a] -> [b] -> [c] -> [d]
zipWith4 :: (a -> b -> c -> d -> e) -> [a] -> [b] -> [c] -> [d] -> [e]
