Drafts 16.1 (macOS) has been released in the Mac App Store, details below.
ICYMI: Drafts 16 introduced action support for the Mac. Read release notes.
- New: Print action steps can now specify page margins (in points). Details
- Fix: Triggering a dictation action on unsupported OS version would report problem, but not properly finish the failed action.
- Change: Switch to custom link identifier in Link mode to fix a few issues with URL highlighting with data detectors.
- Change: Update subscription pitch screen.
- Fix: Vertically align select items in prompts to avoid clipping.
- Fix: Possible fix for issue hidding action bar on 10.13 (High Sierra)
- Change: Tighten authorization scopes requested by Gmail actions based to avoid Google verification issue.
- Fix: Fix for issue where scripted alert might not appear when action was run by being queued in another action.
- Fix: Issue that could prevent extended dictation from working properly if the system timed out listening.
