Drafts 12.1 (macOS) is now available in the Mac App Store, details below. This is mostly a quick release to polish out a details around the new windows features in r12.
New: Add “Window > Float Selected Draft” menu item to open new draft window.
New: Add “Window > Float Selected Draft On Top” menu item to open new draft window floating over other applications.
Fix: Drafts in floating windows should support all Editor menu commands.
New: Button in title bar to toggle “on top” floating status of draft windows.
New: Add “Editor > Navigate” menu item to trigger navigation.
Change: Remove “Navigate” top level main menu item.
New: Add periodic check for subscription status changes
Fix: If same draft was loaded in main editor as other open windows, and the app became inactive directly after making edits, the edits could revert.
Fix: Workspace editor would mis-select sort order for “all” folder when changing flagged sort.
New: Update to MultiMarkdown 6.4.0 (was on 6.3.2).
Great to see window floating. One ask: when I try to minimize or close the main window (and just keep the floating window on screen) every time I type in it or bring it to focus it reopens the main Drafts window. Is there any way to fix?
I know that it can be changed, but….I would imagine that a fair few Drafts for Mac users would use 1Password and likely find ⌘\ (for Draft’s Editor\Navigate command) clashing with 1Password’s ‘Fill Login’ command.
Seems to show the new version, but 12.0.6 downloads, not 12.1 as advertised. Probably an App Store problem. Is there a way to get this direct from site?
You can create your own (and change default) keyboard shortcuts for all applications on the Mac.
I would suggest that doing it too often is likely to cause confusion, but a few here and there can be really helpful.
I just got it to show in the MAS. It says the update was from “yesterday,” but I still couldn’t get it this morning. Weird. Anyway, thanks for the update!
