I’ve confirmed that: drafts5://open?uuid=E19DA953-08AE-428D-8753-0AAA37E3EFE4 works, but when using append/prepend actions, I get Draft Not Found for UUID error
e.g.
drafts5://append?uuid=E19DA953-08AE-428D-8753-0AAA37E3EFE4&text=234
Yes, the problem is with opening the url from terminal for some reason. I tried it with the same URL in Safari and it works, just ‘open drafts5://append’ (prepend and replaceRange) that appears to fail. I tried other draft5 urls in terminal, like search, those works.
I can send you a screen capture of my repo if it helps.
