I use Wunderlist the way some people use omnifocus. The latter is overkill for my needs. Please add Wunderlist integration if possible. Thank you
Wunderlist is no longer being developed, I would suggest looking for a new system as at some point (probably in September with the new iOS) it will cease to work as expected.
I agree. Microsoft is basically rewriting Wunderlist as Microsoft To-Do. Wunderlist’s days are numbered.
For now, if you just want to simply open Wunderlist from within Drafts, you can use the basic Wunderlist URL scheme as an action: wunderlist://
Wunderlist, even before Microsoft bought it, never implemented additional advanced URL scheme support.
