In my Tasks-workspace, I would like to list all Drafts that are either flagged, or have a tag “todo”. I can’t find any way to do this in the documentation.
There is not a way to construct a workspace that does what you describe. You would have to use a different tag to represent flagged status, not the actually flagging feature. Then you could have a workspace that looked for those two tags.
Thanks for confirming, and also thanks for the workaround suggestions ![]()
