I’ve noticed a problem for years that sometimes pasting into Drafts results in Markdown-ified text from rich text (preferred), but other times it strips everything and results in plain text without formatting or markup.
Today, I tracked down when each happens. When using the long-press context menu to paste, you get Markdown. When you use the Paste action (I’m pretty sure the one preloaded on install), the formatting is stripped.
Screen recording: https://shared.heydingus.net/uploads/2024/drafts-paste-behavior.mp4
Is that difference in behavior intended? I pretty much always want it to be pasted in as Markdown. Should I be using a different action?
