Using whisperAI in drafts
Is it possible to use the whisperAI model to use transcription in Drafts?
No, Drafts does not have an Whisper model integration at this time.
This app works well on iOS and when you’re done speaking, you can immediately share the text to Drafts via the share sheet.
Sounds like, based on the WWDC Keynote announcements, Apple is also integrating some at least Whisper-like improved dictation models in iOS 17/macOS Sonora as well.
@agiletortoise
It would be great if Drafts incorporated OpenAI Whisper – either via the Whisper API, or even running locally on Apple Silicon devices.
Whisper’s transcription capabilities far exceed Apple’s and Google’s, at this point.
The difference in quality is stark! It would be great to be able to use whisper to transcribe directly to Drafts. Game changer.
You may be surprised by how much better dictation is in iOS 17 / macOS 14 (still in beta). Apple has incorporated AI models that make it competitive with Whisper.
Sounds good. I’m looking forward to it.
Throwing in my vote for Whisper support. I’ve been using the dictation on iOS 17 and while it’s better it’s not as good.
Actually I am surprised that it isn’t better.
I would be very supportive of Drafts using Whisper or as an alternative, Speechmatics which I have used for video captions and found to be very accurate.
+1 for this feature! I’d be happy to use my own OpenAI API key for such a feature. Perhaps Drafts could implement an automated wizard to help users connect the API to the app, thereby removing the need to charge more for API usage on their part? Just throwing in my two cents, as this would be a game changer.
I too would like to have the ability to directly access Whisper for transcription directly into Drafts. In addition, it would be very helpful to be able to easily choose some of the other Whisper (and ChatGPT for that matter) formatting features such as summarizing, outlining, etc.
I also agree with splitpersonality that we should use our own OpenAI API keys for accessing Whisper, just as we do for ChatGPT.
I am an old dog and my antiquated fingers no longer work well with either software or hardware keyboards. I would be incredibly appreciative to be able to access Whisper based AI transcriptions directly in Drafts!
Same for iOS 18 and Sequioa. Transcription better, but not as good as Whisper.
I currently have my iPhone action button mapped to opening up the dictation mode in Drafts. How would I do this if I have to use SuperWhisper which does support a Record Shortcut action? This app transcribes so much better than Siri, also handles punctuations automatically.
Maybe via Shortcuts?
@sylumer Had run into a problem with using Shortcuts, described on this superwhisper subreddit thread. The other way to do it would be within Drafts but there doesn’t seem to be an option to switch the dictation model from Siri to something else.
Have you contacted the Super Whisper developer about the deficit in the Shortcuts support? That seems the most pragmatic option in my opinion.
There was an already open request on the Superwhisper feedback board :crossed_fingers:.
