I’ve had some success connecting the Todoist REST API to Drafts 5. I’ve now got a script up and running that populates a prompt with a list of Todoist projects which allows me, for instance, to pick which project I add a new task to, rather than everything going in the inbox.
This is the http.request statement (where token is my Todoist token, which I get using the credential module):
var http = HTTP.create(); //create HTML object
var response = http.request({“url”:“https://beta.todoist.com/API/v8/projects","method”: “GET”, “headers”:{“Authorization”: "Bearer "+token}})
One of the best features of the REST API is that you can filter your list of tasks by adding parameters to the statement. I’ve got this working in Pythonista, but can’t work out how to do this in JavaScript in Drafts.
I’ve tried the params element within both the data and the headers part of the http.request statement in Drafts, but I’m getting a 403 error. Is there a way to pass something that is neither “data” nor “headers”.
The data value would typically be used to pass data with a POST type HTTP request. If it’s looking for parameters on a GET request, those would typically be encoded into the URL arguments. There is not a separate object to pass for those, they should be part of the URL used for the request. So your URL passed the request would be:
This is what I’ve got so far for the projects selector - gets a projects list from Todoist, populates a prompt and then will allow me to take action on the selected project. At the moment the actions are done through Pythonista, but I’m in the process of converting that.
The aim is to get to a point where I can do most things I want to do with Todoist from Drafts so I don’t have to lose my focus.
Once I’ve finished I’ll add to the action directory.
// Sort out credentials
var credential = Credential.create("Todoist token", "Todoist API");
credential.addTextField("username", "Username");
credential.addPasswordField("password", "Password");
credential.authorize();
//Get token
var token = credential.getValue("password")
// grab text
const currentContent = draft.content.trim();
//Choose Action
action_list =["New project", "Open Project", "Copy Project ID","Add project note","Update meetings list","Change status", "Add default notes"]
var p2 = Prompt.create();
p2.title = "Select action";
for (var action of action_list) {
p2.addButton(action);
var ActionSelect = p2.show();
var actionSelected = p2.buttonPressed;
//Get Todoist Data
var response = http.request({"url":"https://beta.todoist.com/API/v8/projects","method": "GET", "headers":{"Authorization": "Bearer "+token}})
if (response.success) {
var text = response.responseText;
console.log(text)
projects = JSON.parse(text)
else {
console.log(response.error);
var prompt_text = [];
for (var i = 0; i < projects.length; i++) {
prompt_text.push(projects[i].name);
var p = Prompt.create();
p.title = "Select project";
for (var project of prompt_text) {
p.addButton(project);
var pSelect = p.show();
var projectSelected = p.buttonPressed;
console.log(projects[i].name)
if (projects[i].name == projectSelected) {
var project_id = projects[i].id;
actionSelected = encodeURIComponent(actionSelected)
textToAdd = encodeURIComponent(currentContent)
var url= "pythonista://Todoist/td_project_actions?action=run&argv=" + project_id + "&argv="+actionSelected+"&argv="+textToAdd
console.log(url)
var result = app.openURL(url);
I don’t really understand how it works, it just does. I just copied the example from the website.
Basically first time it runs it will ask you for the relevant password/token etc, after this, it will find the password so you don’t have to enter it again.
I believe Remember The Milk authorisation works differently (the user has to perform a manual action at a specific URL), so I guess I just need to start experimenting.
