AFC
1
I have a 2-step action with step 1 being a script and step 2 the pre-configured action to save to Dropbox.
I want to use one of my script variables in the 2nd step. What would be the best way of doing this? I’m trying not to use the clipboard…
Thanks
Take a look at setTemplateTag(). That should do what you want.
AFC
3
Thanks @sylumer. That resolves it. Somehow I thought that one was for Draft tags but I misread it. Cheers
Link on github is broken (404)
sylumer
5
That’s simply because that link is over two years old and things have changed in that time
It’s pretty easy to search for and find it on the scripting site - setTemplateTag()
