I use almost exclusively the Apple Pencil to annotate text and put some parts in bold. This is much faster and precise than using my fingers and I absolutely love it.
It would be excellent to be able to use the double tap on the Apple Pencil to put the highlighted in bold for example or be able to use it to cancel the last action.
I do not believe it is possible to implement this sort of Pencil integration. I’ll make a note to look into it, but I’ve not seen any APIs from Apple that allow apps to work with Pencil taps for arbitrary functions in apps that are not otherwise using the Pencil.
I use Fiery Feeds as my RSS reader and I use the double tap to change articles and this is super nice to be able to use the Apple Pencil as a “remote control” and be able to lay down the iPad and continue reading from further away.
If it was possible that would also be great if it was possible to scroll down with 1 page increment in the Draft app when we double tap the pencil.
Anyway, thank you for your great app that I enjoy using daily!
