I love Drafts but this issue is driving me crazy. I use Drafts as a scratch pad all the time and I’ve seen this happen before but today I had to take the time to write it up. The steps to reproduce are very easy:
- Copy a piece of text
- Paste it into drafts
- Hit enter
- Paste it again (same or different text, doesn’t matter, just wanted to make the reproduction simple)
- Cmd + Z (undo)
You will lose both lines of text, this will happen for more than 2 lines as well. I use Cmd+Z a TON and I’ve never seen behavior like this. Even worse you can completely lose what you had if you:
- Copy text A
- Paste into Drafts
- Hit Enter
- Copy text B
- Accidentally hit a key
- Paste into Drafts
- Notice you hit a random key
- Cmd + Z to undo so you can delete the extra letter then re-paste
- Backspace before you notice you lost everything
- Now you’re screwed, you can’t Cmd+Shift+Z to get it back
Cmd+Z should NEVER undo more than the last action that was taken, I have no clue why it would undo multiple things.
