Unable to append or prepend using Quick Capture
I’ve got a Drafts Pro subscription so this should work, but I cannot get Quick Capture to show the append/prepend buttons after activation. All I get is the Save as New Draft. I’ve got v26.3.5, and I’m on Mac OS 11.3.1.
Anyone know how to get Quick Capture in Drafts Pro to work as designed?
Thanks.
Are other pro features enabled?
you have to select a draft in the list to append/prepend to first. You get see the list of drafts by clicking the small disclosure arrow at the bottom left of the quick capture window.
Brilliant, thank you. I was missing the need to press the plus sign you highlighted.
