I’m trying to figure out the best way to integrate with Grammerly. I need all the writing help i can get. The grammerly IOS app is a keyboard so it doesn’t work with external keyboard.
Grammarly doesn’t have an API which they allow people to use, so I have found the best approach is to write my document, switch to the software Grammarly keyboard and press the green G in the top left.
Rosemary with the Mac version of Drafts can you figure out a way to create an action that would send text to Grammarly through either the webpage version or the Grammarly application? Thanks
If Apple would allow other keyboard to be active with having the Smart Keyboard attached it would be easier. I just copy and past into either prowriting aid or gramerly. Just looking for a short cut.
