Hey,
I have a whole batch of drafts, maybe 300, which start with a manual date, what I mean is I typed the date in on each draft when I created it. (doh). Anyway, I’d like to transform the date so they are all the same format.
At present they are in the format:- (some notes may be d-m-yy or dd-m-yyy etc etc)
23/3/21
23/03/21
23/03/2021
I’d like them to read
2021-03-21
so
yyyy-mm-dd
I don’t mind selecting the text in each draft and hitting a key combo or pressing an action, or is there a better way I can achieve this on a Mac ?
I think this action should work. Try it on a selection of drafts one by one and check the results. Revert using version history if you find an issue. Once you are satisfied it works as expected, select all the drafts you want it to run against and run the action to batch process all of the selected drafts,
The action uses a single script step with the following code.
let astrTitle = draft.title.split(" ");
let strDate = astrTitle[0];
//Only process if it looks like we have a date
if ((strDate.match(/\//g) || []).length == 2)
//Build the new date
let astrDate = strDate.split("/");
let strDay = ("0" + astrDate[0]).slice(-2);
let strMonth = ("0" + astrDate[1]).slice(-2);
let strYear = ("20" + astrDate[2]).slice(-4);
//Rebuild and replace the draft title
let astrContent = draft.lines;
astrTitle[0] = strYear + "-" + strMonth + "-" + strDay;
astrContent[0] = astrTitle.join(" ");
draft.content = astrContent.join("\n");
draft.update();
This should work on Mac, iPad and iPhone, though the way you run an action against a batch of drafts can vary a little by platform and if you are using pointing devices, keyboard access, etc. But you could certainly run this action against all of your batch of 300 drafts in one shot rather than selecting each one at a time to run it.
Hey thanks! I tried this but the action doesn’t seem to run or at least it does nothing.
I created a test draft and tried double clicking the action but nothing.
Hey @sylumer hope you are ok. I haven’t used this action recently. Is there anything in drafts that changed in the past year or so which would stop it working?
It just does nothing, no error etc.
I tried deleting and re adding the action.
Many thanks!
D
Shouldn’t be. It processes the text of the first line and replaces it. If anything about that had changed, chances are hundreds of actions would no longer work in some way or other.
If nothing is happening, my guess would be is that there is no match - I.e. the title does not end with a match able date.
Perhaps you could share some example content that does not work? Place it between triple back ticks to make sure we get exactly what you have. Then we can try and reproduce/explain.
