One option that I would like to see is the ability to toggle that the title of the draft is found in the metadata when writing in Multimarkdown. My issue is that I will write a draft - currently the first line is the title and then I have a MMD metadata block. When I preview the draft then the metadata block is visible. It would be nice simply to have a metadata block as the first part of the draft (as normal MMD) and then Drafts works out that the title of the draft is the title metadata and exposes this as the title in the Inbox, Archive and Flagged and as the [[title]] tag.
I do not think it would make sense to change the behavior of the [[title]] tag for this specific case, because it is specific to MMD and not wide used.
That said, if it is a case you commonly use, your own preview actions could be edited to use [[body]] to generate the preview instead of [[draft] in their templates, and it would work to generate the meta tags properly because MMD would be getting those as the first content and ignoring the first line.
Thanks for your reply. I guess that I might be considered an edge case and understand that not many people might not be bothered in the same way. I guess I am trying to keep some consistency in how MMD is implemented. I really like Drafts and it has taken over my long term storage of all my notes rather than simply being an environment for short term notes.
While changing the preview to [[body]] rather than [[draft]] certainly solves one problem I am still left with the rather unsightly mess of “Title: blah blah” appearing as my titles in my Archive/Inbox etc
I will echo this one… just a setting in the MMD options that lets me hide the metadata block from the preview would be nice.
I do see your point about how it makes [[title]] inconsistent… I’m going to have to think about that.
From what I have been reading, YAML blocks can appear at the top or, after a blank line and are delimited by —- as follows
Title
title: blah blah blah
author: blah jones
published: 2020-07-25
—-And on we go
This preserves the [TITLE], but causes them to show in preview. Is it possible to have an option to ignore YAML blocks?
I use a lot of yaml frontmatter in my documents which muddies up the list of drafts. It would be great to populate the [[safe_title]] tag (and also what Drafts shows in the list) with either the yaml frontmatter title value or, if that does not exist, the first line after the beginning yaml block. Yaml blocks are common in several markdown variants (I use Pandoc most frequently) and also in markdown prepared for blog posts, e.g. in Jekyll, Pelican, Hugo, etc.
Or, since Drafts does not currently utilise YAML, you specify the title (line 1) as your “Drafts Title”, and then pass everything but that title on to wherever your YAML is being used. As noted above this would be a case of using the body of the draft rather than the full content of the draft in your actions.
If you actually wanted to use the title in your YAML and not duplicate the information, then you could build that line of YAML from the title via the actions you are using (and just by creating a single source action step to do it every time with minor effort).
