Toggle Tag Entry?
I using Keyboard Maestro to toggle many of the gui elements of the Drafts window (e.g., Show|Hide Toolbar).
This task is easy with everything except Tag Entry. As far as I can tell, there are no menu conditions that change when the Tag Entry field is visible. For example, View>Tag Entry and View>Hide Tag Entry seem to be enabled, regardless of the visibility of the Tag Entry field.
Is there some other way to automate the toggle of Tag Entry?
TIA.
