Is anyone actively using the Todoist.createProject() API?
I used it in the past and it worked without a problem.
Now the project gets created but I receive an HTTP 500 (internal server error) as response.
I‘m already in contact with them but I wanted to ask if this is a general problem.
It will create a test task first and display the response. Then it will create a test project and alert the response, if it says „undefined“ there was an error and the response is logged in the console.
