Did you know you can use flags in Drafts similar to how Apple Notes “Pin Note” feature works? If you want your flagged notes to always appear at the top of your inbox, enabled the “Sort Flagged to Top” list option. When enabled, flagged drafts will always be sorted first.
What this to always be your default option? As with any list option changes, choose “Save as Default” after to update your default workspace options - these get applied whenever clearing the list with the (x) button.
