Theme not applied correctly in edge cases
In some edge cases, the theme is not applied correctly (on MacOS) on the current note that is displayed. What happens is that font-sizes, font-weight and font-variant are not applied correctly (or completely lost) in the following cases:
  • When switching from light/dark mode while the Draft window is active.
  • When switching a theme
  • When soft closing Drafts (i.e. the red button of the stop-light control) and reopen. It opens the last note and the ‘styling’ is gone.
Once you start typing or switch the active note, all is restored.
I’ll take a look, thanks for the details.
I cannot reproduce these issues here. In what version of Drafts and OS are you seeing them? Which editor mode (Editor Settings > Advanced) are you using?
  • Drafts v52.0.1
  • MacOS 26.5
  • Happens with both the modern and legacy editor
