Hi!
I’m starting to move my TextExpander snippets to using built-in Drafts constructs.
I believe most of my snippets would work fine as autocomplete expressions, but is there a way to chain/invoke several of them from another one?
Let me give an example: In TE I have these snippets:
sdate(inserts date like 20250124);stime(insterts time like 21.32.44)
And then another snippet that chains them:
..ttwhich is defined in TE as%snippet:sdate%-%snippet:;stime%and inserts both - like 20250124-21.33.55
So I have created autocompletes for the building blocks using [[date|]] templates, but I’d like to know if I can create one that calls both(**)
Thanks!!
(**): Yes, I know that in this case I could probably create a single autocomplete that generates the output I want using a date template; but this is just one example of what I’m trying to do - I have several other examples!
