Hi; For some reason my snippets from textexpander aren’t auto-expanding as the did in earlier versions and currently do in other apps… does anyone have a suggestion for what might be the issue?
Are your snippets working in apps other than Drafts? There’s no integration involved on Mac, TextExpander does it’s thing at the system level, so I don’t know of anything that could stop if from working Drafts that would not also be stopping it everywhere.
Yes the snippets work fine - ie auto-expand - in gmail, for example…
Everything is working fine for me. Simple and Fill-In snippets are working as expected.
I know it’s hack-y advice, but I’d try a reboot.
