I read Dr. Drang’s article talking about Drafts 5 recognition of Taskpaper syntax. Back when Jesse was maintaining Taskpaper on IOS I used it extensively and I would love to return to it. Drafts appears to be the ideal platform to support it. When I enter Taskpaper format text into a draft however I do not see any of the formatting that Dr. Drang spoke of in his article. What am I missing?
Have you set the draft to use Taskpaper syntax?
If not…
See syntax highlighting section on this help page.
https://getdrafts.com/editor/appearance
Select Taskpaper as the syntax.
Yes, late last night I finally stumbled across that feature. I thought I had read the fine manual, but I ended up going to bed telling myself once again RTFM. Anyway, thanks for confirming. Drafts just continues to impress.
