The scopes section of the syntax documentation suggests I should be able to apply a colour to a scope by using, for example color.green.
This works when I set something in a pattern section, as per the Demo Rainbow syntax (I also double-checked to see it was indeed defined in the theme I was using), but it does not seem to work when I use this for the scope of an element such as the key, in a link definition (see below). Replacing the colour entry with text options such as text.bold, or text.underline work fine for this, but not colours.
The documentation seems to suggest I should be able to set the colour of the link as it is a scope and the text styling seems to be applied just fine. The behaviour I am observing suggests otherwise, or the very real possibility I’ve not taken something into account about how to do this.
"linkDefinitions": [
"match": "(\\[\\[)(((d|u|s|w|google|wikipedia|bear|url):)?([^\\[]+?))(\\]\\])",
"templates": {
"": "drafts://open?title=[[value]]&allowCreate=true",
"google": "https://www.google.com/search?q=[[value]]",
"wikipedia": "https://en.wikipedia.org/wiki/[[value]]",
"u": "drafts://open?uuid=[[value]]",
"d": "drafts://open?title=[[value]]&allowCreate=true",
"bear": "bear://x-callback-url/open-note?title=[[value]]",
"w": "drafts://workspace?name=[[value]]",
"s": "drafts://quickSearch?query=[[value]]",
"url": "[[value_unencoded]]"
"enabled": true,
"captures": {
"value": "5",
"key": "4",
"prefix": "1",
"suffix": "6",
"link": "2"
"scopes": {
"key": "color.green",
"value": "",
"prefix": "markup",
"suffix": "markup"
I was extra careful to make sure that I dropped the British “u” from “colour” when I was trying this - it wouldn’t be the first time that had caught me out!
Can anyone confirm if this is possible or not, and if it is possible, how to apply a colour to an element of a link definition?
I am testing on:
- Drafts: 27.5.37 (Beta).
- MacOS: 11.4.
