hello
is that possible?
Thanks
hello
is that possible?
Thanks
Drafts does not sync files and nvAlt is file-based. Drafts’ contents are instead stored in a database.
You can import and export, but the result is that it cannot sync in the way I think you are probably hoping for.
1Writer is your best bet if wanting to compliment nvALT with an iOS app referencing Dropbox text files. You probably know that already though.
