When I type a letter “v” in Drafts (and only in Drafts), it does not insert a “v”. Instead, an alert-type box pops up with a chime sounding like some Drafts Action, saying “Select All”. It then disappears. Nothing gets selected, but I am unable to type any word with a lowercase v in it. I have to type uppercase, then change case!
I suspect I installed some action that is treating “v’ like a keyboard shortcut, but I’ve gone thru the lists of actions I have (dozens) and looked at the keyboard shortcuts that are assigned and can’t find any with “v’.
Anyone have any ideas that might help me get rid of this problem?
Any chance you are using a smart keyboard? I find that sometimes my command key gets (invisibly) stuck and so a normal “v” ends up being interpreted as command-v.
On iPad you can hold down the command key to get an overlay of all keyboard shortcuts to find it. On Mac, browse in the “Actions” menu in the main menu - not ideal, but should help locate it.
The log! That did it; an action titled SelectAll had “v” for a shortcut. I may have accidentally set that. Anyhow, I changed it and now I can use “v” again! Thanks. I’d never looked into the log before; what a useful feature!
