Can someone help me?
I have drafts with the text “Episode: “ followed by a number, starting with 01.
I want to find the drafts with an episode followed by a number and then sort the drafts numerically in descending order.
Is this possible?
Is this possible?
Is this a one-time task, or something you going to have a repeated need for?
Do the drafts all start with that text? If yes, you could just search above the draft list for “title:Episode” and sort the list by “Text” to get them all in order.
Not sure what you want to do with them once you have them sorted, however.
Thank you. I imagined something more complicated using JS, but I like the simplicity of moving the “Episode” to the title with the person’s name below it.
If this is something you are doing regularly, I might suggestion you consider tagging these drafts with episode (or the show name, or whatever), so they can be more accurately filtered easily - and, also, consider setting up an “Episodes” workspace with the filtering and sort options pre-selected so you can easily get a view of just those drafts.
Great suggestion. Thank you.
