Hi,
I am trying to speak some text from the clipboard in shortcuts and return to drafts after the audio has finished.
The called shortcut is simple
See https://www.icloud.com/shortcuts/6514d93acf0d4c1fabc97e87211f1e0b
It gets a text parameter with a language to make a multiple language output possible and speaks the clipboard content.
Example calls triggered as a link from draft are as follows.
The will not be able to open drafts again.
Has anybody the same problem with non beta software? (I am running ios public beta)
my information comes from [Use x-callback-url with Shortcuts - Apple Support](https://support.apple.com/en-il/guide/shortcuts/apdcd7f20a6f/3.2/ios/13.
shortcuts://x-callback-url/run-shortcut?name=Callback.speak&input=text&text=english&x-success={{drafts://create?text=[[clipboard]]}}
shortcuts://x-callback-url/run-shortcut?name=Callback.speak&input=text&text=deutsch&x-success={{drafts://x-callback-url/create?text=[[clipboard]]}}
shortcuts://x-callback-url/run-shortcut?name=Callback.speak&input=text&text=deutsch&x-success={{safari://}}
Thanks
