Any plans to include Slack integration?
(Awesome app btw - loving your work!)
For what it’s worth Slack do publish some [Slack URL scheme information](https://api.slack.com/docs/deep-linking], but I don’t see anything in there about posting. Just jumping into the app and opening things up.
Workflow.is has a simple action for posting to Slack. You can create a one step Workflow to post input to Slack. Then, use the Drafts Action Run Workflow to call that workflow with the template of [[draft]].
Great, I’ll look into it. Thanks for the info!
workflow is no more and Shortcuts doesn’t do out of the box Slack.
