Simple Scan is a really handy little app that is unfortunately prevented from realising its full potential by the operating system (like many other apps).
The Files format suffers from the fact that it is still not possible to simply save files in a folder of another app.
At the WWDC keynote next Monday, we will find out how iOS/iPadOS will become “more like” macOS. But since, if the leaks are correct, it seems to be mainly about iPadOS, there will probably be a focus on the user interface and once again not on basic functions such as the file system.
Hence my question whether Simple Scan can also get a UUID method. This would make it possible to save in folders at least of apps that allow access to the UUIDs of their folders.
It would be even better, of course, to have full X-url(-callback) support. With which you could also pass data such as the create date, tags etc. if the target app supports this.
If the user interface of Simple Scan remained unchanged, maybe there would have to be a variable for the data type in the X-url.
Example: In DEVONthink To Go, my favourite target app, many different file types can be created, the X-url would have to contain explicitly which one.
This is how the X-url part of my “Send to DEVONthink to Go” action in Drafts looks like:
x-devonthink://x-callback-url/createmarkdown?title=[[created|%Y-%m-%d-%H-%M-%S]]&text=%0D[[draft]]&tags=[[tags]]&destination=[[destination]]&label=[[label]]
The createmarkdown part would be the result of the variable if Text is the chosen format (or at least that is what I would prefer over simple txt), if the chosen format was PDF it would be createpdf etc. The user would somehow have to set this. True, this contrasts the “Simple” in Simple Scan. But the actual scanning would indeed become simpler, just not the setting of the Custom Destination.
Of course, you could create three DEVONthink To Go related Custom Destinations, one for PDF, one for an image, and one for text, but it would be better if you only needed one and the X-url would be automatically adapted to the file type by Simple Scan.
