I’ve done some experimenting with shell scripting in Drafts 19 and have run into a problem. This is long because I don’t want to leave out details that might be important.
First, scripts run through the ShellScript.create and execute system described in the docs run in an non-interactive shell, which means they have a very restricted PATH, just
/usr/bin:/bin:/usr/sbin:/sbin
So if you want to use a Perl, Python, or Ruby that’s more advanced than what comes with macOS (the stock Python, for example, is years out of date), you can’t simply start your script with a line like
#!/usr/bin/env ruby
as Greg does in the example in the docs, because env won’t see where you have the newer version of Ruby.
There are several ways to get around this, with varying degrees of flexibility. A method I’ve used is to give env a new PATH:
#!/usr/bin/env -S -P${HOME}/anaconda/bin:${HOME}/opt/anaconda3/bin:/usr/local/bin:${PATH} python
For me, this has two advantages:
- By using the
HOMEenvironment variable, it will start by looking in the user’s home directory without needing to know what the username is. This helps if you have two computers with different usernames and if you’re sharing a script with someone else. - By giving a new, multidirectory
PATHto search, you can account for differing installations across machines.
Unfortunately, when I’ve tried this in a single-step action using this script,
let script = `#!/usr/bin/env -S -P${HOME}/anaconda/bin:${HOME}/opt/anaconda3/bin:/usr/local/bin:${PATH} python
import sys
print('.'.join(str(x) for x in sys.version_info[:3]))`
let runner = ShellScript.create(script);
runner.execute();
alert(runner.standardOutput);
I get this error:
Script Error: ReferenceError: Can’t find variable: HOME
Line number: 1, Column 41
This suggests that the HOME environment variable isn’t set, but if I run this script
let script = `#!/bin/bash
echo $HOME`;
runner.execute();
it gives the right answer, which means HOME is set.
Anyway, the shebang line I’m using here for Python is one that works in Keyboard Maestro, which is the closest analog to Drafts I can think of. There are definitely ways I can get around this problem, but it does seem wrong that it isn’t working the way I expect it to. Maybe there’s a difference between running env directly and running it by way of JavaScript?
