Is there a way to set values to a “Configured Value” from a script? Even better, is there a way to set a Configured Value without showing that value in the settings?
I was storing these values in a Credential or creating a “settings file” with FileManager, but these introduce UX problems, especially for less knowledgeable users.
It looks like we are most of the way there.
Here’s my use case: I need several values for API calls in the script. To make things easier, especially for less knowledgeable users, I’d like to ask the user to paste a URL into a Configured Values field and have the script parse the API values from the URL. I need a fallback in case the parser fails (because the user’s URL is something I didn’t think of). My best fallback idea is to use a Prompt to ask for the missing API values–it adds complexity to the UX only if errors happen. The question is: What do I do with the values from the Prompt? Writing those values to hidden Configured Values would be perfect, but writing to regular Configured Values would be ok.
Otherwise, I think I’ll need to remove the URL and the parsing feature, and just ask for the API values directly.
