I have been using Sepia as a foundation for a new theme - and in my new theme I was modifying the appearance of a quote
eg;
“this is a quote”
I was getting a message ‘Missing Scope’ - text.quotation’
Firstly - once you have brought the theme into the new theme editor - when you export you lose the ability to see the layout of the file - it now runs as one big giant text stream - because of this - I couldn’t add the missing scope myself - novice … I am sure someone who knows the syntax properly could do this … not me.
So I went back to the default Sepia and decided to build again - assuming somewhere along the line I must have deleted that particular scope.
But even in the default sepia scope the same issue - ‘missing scope - text.quotation’
Regarding the “big giant text stream,” if you open the exported JSON file into a code editor like TextMate and use the JSON formatting command (in the TextMate JSON Bundle), that should neaten the formatting for you. Any JSON parser (or web-based JSON parser) should have this ability.
In terms of the scope issue, if it’s permissible for you to post the JSON code or a link to the file, that might help diagnose the issue. I’ll try to take a look at the root Sepia file in the meantime when I have a chance.
You cannot fix it for the built-in theme. It’s not a significant issue in this case, and has been fixed in the current beta cycle, just not out in a release. You can use the theme, it won’t cause any problems.
