So I’m using the standard Move to Trash action. I want to use my stream deck to trash whatever draft is up in the editor. If I run the action from the keyboard or however else, it works fine. But if I run it from a URL (drafts://runAction?action=Trash) I get a check mark as though it ran but nothing happens.
Perhaps this is related. When I run the advanced print / PDF from outside (via Stream deck —> URL) it runs the action and I get the normal export window but there is no text in what gets exported.
(Advanced Print/PDF export | Drafts Directory)
What am I doing wrong?
