I was hoping someone here could help me with a bit of a round-about way I’m utilizing Drafts to (hopefully) upload an image to Wordpress. I think my issue might lie in a slight misunderstanding of what exactly the Wordpress XML-RPC expects when receiving a file.
So, the general workflow is this. The action is triggered and it immediately switches over to Shortcuts and runs a shortcut I’ve built to get the image and related information. Shortcuts passes a dictionary back to Drafts of format:
shortcut_result = {
string alt,
string data,
string name,
string title,
string type
Most of this is just metadata for the image. Key to this particular issue is that in the workflow, I let the user pick a photo, then I convert it to base64 and store it in the shortcut_result.data dictionary entry as a string.
In Drafts, after setting up the credentials, I then construct the following request to send to Wordpress:
let the_image = JSON.parse(draft.getTemplateTag("shortcut_result"));
let method = "wp.uploadFile";
let params = [
1,
cred.getValue("username"),
cred.getValue("password"),
bits: the_image.data,
name: the_image.name + "." + the_image.type,
type: MIMEtypes[the_image.type]
While this successfully posts, the image file created on the server is corrupted and won’t display. I also tried adding polyfills into the script for atob() and btoa() support, which didn’t seem to work the way I tried. Lastly, I stole the Base64 constructor from a Javascript XML-RPC library, converted the base64 back to binary to pass into the Base64 constructor, and then tried sending the object:
var Base64 = {
binary bits,
func encode,
func decode
This didn’t work, nor did sending Base64.encode().
I really think I’m just missing something on how to package the binary data for Wordpress to properly ingest. MIME types are correct, and if I paste the base64 data Shortcuts returns into a base64 → image decoder the images appear properly, so it’s all in how I’m sending the data to Wordpress.
Anybody have any advice? Is there something with Drafts’ WordPress class I could be missing that is causing the problem? Some other way I could package the base64 data?
