I am trying to send a draft to outlook, but when I run the action it opens in my Chrome gmail account. How can I get drafts to send it to Outlook rather than Chrome?
Are you using this Outlook action from the Directory?
I do not believe Outlook on the Mac has any direct URL scheme integration points on the Mac. This action, when run on the Mac, uses a mailto URL, and, as such, will open your default email client – not necessarily Outlook. If Outlook is set as your default email client, then it would open Outlook. You can change your default client on the Mac in the Mail app Settings.
Thank you, that fixed it. I went into Mail setting and I saw that the default reader was Google Chrome, I changed it to Outlook and now it works perfectly! So simple, thank you for your help!
