I am quite new to Drafts but really felt in love with the clean interface and the great integrations. What I use heavily is Rosemary Orchards Action Set to create tasks in OmniFocus with TaskPaper. Since I write a lot of invoices I would love to have a solution quite similar to Rosmarys approach with OmniFocus. The largest part of my mails is always the same, the only changing thing is the recipient as well as the date. How can I add to the Mail or Airmail action a stop to ask for the placeholders and send them afterwards to the respective app? I compose my mails with Markdown, in case thats important for a solution.
Thanks for your quick reply cpac. That’s exactly what I would like to do - but have absolutely no clue how to do it. Sorry, absolute beginner when it comes to draft. Do you have a hint how to get this done?
I’d create a new action and use some of the pre-defined steps like “Insert Text” “Define Template Tag” “Prompt” and “Mail” to try to build what you’re looking for.
Experiment with them. Add them one at a time. Tackle each piece of your overall action one bit at a time.
Thanks a lot for the links! Already tried a few things, however, not really successful so far. The existing solutions seem to create a new draft with the replaced placeholder content. However, I am aiming for a way to replace them and send them to Apple Mail or Airmail directly. Means, the original file remains untouched.
