First post here. I am trying to create an action that uses the OpenAI chatgpt4 API to summarize an email imported from Drafts Maildrop, and appends the response to the bottom of the message.
I have successfully gotten it to the point where the entire HTTPResponse object gets added to the bottom of the draft. But I don’t want the whole response object as a string - I just want the answer text.
This is the script I wrote
const draftText = editor.getText()
// create OpenAI object
let ai = new OpenAI()
// make API request
let response = ai.request({
"path": "/chat/completions",
"method": "POST",
"parameters": "draftText",
"data": {
"model": "gpt-4",
"messages": [
"role": "system",
"content": "[my instructions for summarizing the message here]"
{"role": "user",
"content": draftText
// report status
console.log(`CODE: ${response.statusCode}
ERR: ${response.error}
${response.responseText}
let content = `${draftText}
editor.setSelectedText(content)
// Get the current text from the Drafts editor.
const draftText = editor.getText();
// Create an OpenAI object.
let ai = new OpenAI();
// Define the chat prompt for summarization.
const chatPrompt = `Summarize the following message:\n\n===\n${draftText}\n===\n\n===\n`;
// Use the quickChatResponse method to get a quick summary.
let answer = ai.quickChatResponse(chatPrompt);
// Check if the answer is defined before proceeding.
if (typeof answer !== 'undefined') {
// Prepare the content to be inserted in the Drafts editor.
const contentToInsert = `\n\n===\n${answer}\n===\n`;
// Insert the generated content at the cursor position.
editor.setSelectedText(contentToInsert);
} else {
console.log("Received undefined answer from quickChatResponse.");
If you are wanting to call it directly, the full example would look something like this:
// Create an OpenAI object. This object is used to interact with the OpenAI API.
// Make an API request to OpenAI's chat completions endpoint.
// The API endpoint path for chat completions.
// The HTTP method for the request.
"method": "POST",
// Parameters to send with the request. In this case, "draftText" seems to be specified as a parameter, although its actual use is not clear.
// The payload data for the request.
"data": {
// Specify the model to use (GPT-4 in this case).
"model": "gpt-4",
// The sequence of messages to send to the model.
"messages": [
// The first message is from the "system" to give instructions to the model.
"role": "system",
// The second message is from the "user" and contains the text to be processed.
"role": "user",
// Log the status code and any errors to the console for debugging.
console.log(`CODE: ${response.statusCode}\nERR: ${response.error}`);
// Parse the raw JSON response text to get it into object form.
let parsedResponse = JSON.parse(response.responseText);
// Extract the message content from the first choice in the response.
let messageContent = parsedResponse.choices[0].message.content;
// Prepare the content that will replace the selected text in the Drafts editor.
// It consists of the original draft text, followed by the model's response, separated by '==='.
let content = `\n\n===\n${messageContent}\n===\n`;
// Replace the selected text (appends when no text is selected) in the Drafts editor with the prepared content.
editor.setSelectedText(content);
Thank you! That worked perfectly. I will use the quickChatResponse method for this, but I appreciate you giving the solution for the direct call as well.
