Searching for emojis in a Draft on iOS vs. MacOS
On iOS I can search inside a large draft for emojis (which I use to mark and log things), but it doesn’t work in MacOS. I assume it’s actually an Apple issue and not a Drafts issue, but was wondering if anyone knows if there’s a fix for that — a setting or something I’m missing.
Thanks.
I’m not having any trouble searching for Emoji on either platform.
Could it be specific to how you are searching (advanced vs. regular find - both work here)?
To the emoji character? Some of them are a bit weird and composite characters, but those don’t seem to be causing a problem here.
Oh weird; it is only certain characters. I was just checking using :baseball: and it works on my phone, but not my Macbook. I just tried :books: and it works on both. So probably just some fucky character thing.
Interesting, because those same characters seem to work fine here on both platforms. :man_shrugging:
Does using advanced find help?
Same result. Er… 0 results. No idea what’s happening.
