Is there any way to create an Action that will enter
title:"" and position the cursor between the quotes
in the search field of the Drafts List?
I’ve tried with TextExpander which works on the Mac but not on iOS.
Thanks
Bob
Thanks
Bob
Not exactly what you have described, but this might be an option for you.
On running, it will give you a prompt to enter the title text. Select OK (the default button) to proceed, and it will create and load a temporary workspace with the title search string set.
So like I say, not exactly what you requested, but it should give the same overall result of a title search.
Thanks, a million
Bob
Works great
Thanks
Bob
Maybe this is also worth to take a look
@FlohGro FYI: Drafts built-in search supports regex using / / syntax. It would be more efficient than looping over the whole library to build a result.
Oh that’s nice - wasn’t aware of that ![]()
Now I can remove this from the action ![]()
