The file name should be ‘yyyy_mm_dd_first_line_of_draft_downcased_and_underscores_replace_spaces.md ’
So far I have this URL action:
(Dropbox Action)
File: [[date|%Y_%m_%d]]_[[title]].md
Path: /folder/
Template: # [[draft]]
But the title is still mixed case and has spaces. Do I need a script to do the file name manipulation? I’m terrible with JavaScript so any tips would be helpful.
This line creates a new custom tag called filename. filename is set to contain the ‘safe title’ of the draft with spaces replaced throughout (the spurious g you might spot above indicates a global replace) with underscores, and the whole thing converted to lower case.
Note I’ve not used ‘title’ but rather ‘safe title’. If the draft title contains characters that have special meaning in a file path (e.g. slashes), these can break the saving. The safe_title tag is a built-in Drafts tag that strips out invalid characters.
Once we have a custom tag we can use that in the Dropbox step like so; replacing your use of the title tag (but note you would have been better off leaving in the Dropbox default safe_title tag for the reasons described above).
