(Along the way, it also adds headers to create a proper Jekyll blog post, and demonstrates the Credential object in use).
I just wanted to write a paragraph or two, and turn that into a blog post with one action, without needing a third-party app. I babbled about it on my blog, but the JavaScript itself is probably of most use here:
const credential = Credential.create("GitHub blog repo", "The repo name, and its credentials, hosting the Jekyll blog.");
credential.addTextField("username", "GitHub Username");
credential.addTextField('repo', 'Repo name');
credential.addPasswordField("key", "GitHub personal access token");
credential.authorize();
const githubKey = credential.getValue('key');
const githubUser = credential.getValue('username');
const repo = credential.getValue('repo');
const http = HTTP.create(); // create HTTP object
const base = 'https://api.github.com';
const txt = draft.content;
const posttime = new Date();
const datestr = `${posttime.getFullYear()}-${pad(posttime.getMonth() + 1)}-${pad(posttime.getDate())}`;
const timestr = `${pad(posttime.getHours())}:${pad(posttime.getMinutes())}`;
const slug = String((posttime.getHours() * 60 * 60) + (posttime.getMinutes() * 60) + posttime.getSeconds());
const fn = `${datestr}-${slug}.markdown`;
const link = getLink();
const yaml = {
layout: 'post',
date: `${datestr} ${timestr}`,
category: 'micropost',
title: '""'
if (link) {
yaml.linkURL = link;
let preamble = "---\n";
for (const f in yaml) {
preamble += `${f}: ${yaml[f]}\n`;
preamble += "---\n\n";
const doc = `${preamble}${txt}`;
const options = {
url: `https://api.github.com/repos/${githubUser}/${repo}/contents/_posts/${fn}`,
method: 'PUT',
data: {
message: `micropost ${datestr}`,
content: Base64.encode(doc)
headers: {
'Authorization': `token ${githubKey}`
var response = http.request(options);
if (response.success) {
// yay
} else {
console.log(response.error);
function pad(n) {
let str = String(n);
while (str.length < 2) {
str = `0${str}`;
return str;
function getLink() {
var p = Prompt.create();
p.title = 'External link';
p.message = 'If this is a link post, we need a link.';
p.addTextField('externalLink', 'Link', '');
p.addButton('Use');
p.addButton('Nope');
const didSelect = p.show();
const link = p.fieldValues.externalLink;
if (link && p.buttonPressed == 'Use') {
return link;
return null;
