Over the past month I have been improving this Safari extension in a lot of little ways.
I have found that that I use it all the time to save articles to read later, Import text to be processed by AI actions, get around pop-ups and paywalls. It’s the new edge of the blade on my Drafts App Swiss Army knife.
But today has reached a new milestone. Version 2.0.2 is being released for iOS and MacOS in the Mac App store!
One of the major little features is that if a page isn’t parsing correctly you can enter the url under the advanced tab and get new parsing suggestions.
I am assuming that the extension uses the Drafts create URL scheme to create the draft. Would it be possible to have an option which we could choose in the Cat Scratches settings to use the run action URL scheme instead, with a specified action? This would allow post-processing of the content within Drafts, by JavaScript for example, before the draft is created.
Awesome! Thank you for this tool, which saves me precious time. If we could manage the date format with more options (such as reducing it to the current date—you understand that I’m not a coder :-), that would be great
Thank you a thousand times.
Glad it helps! Good idea. I’ve just implemented it and submitted it. You should see it in 2.1.1 (I don’t know if they review extensions on a Saturday but it might come out then).
I’ve installed 2.1.0, and it’s doing just what I’d hoped thanks! I’ll report back how I’m using it once I’ve coded up the action.
A tiny point: I can only tell it’s 2.1.0 not 2.1.1 yet by looking in the App Store install history. It would be good if the current version number were visible when you open the Cat Scratches app from its icon on the home screen.
