When I run an action that has only an apple shortcut, when it ends there is a recent Drafts note on the screen. It’s not the note I had when the action started, but it was pretty recent. I expected it to be a blank.
My guess is:
- You have the action configured to archive or trash the draft after running using the “After Success” option - which will tell drafts to move that draft and load another after the action.
- You have Focus Mode enabled.
If focus mode is enable, and a draft auto-archived, the next draft in the list is loaded for processing, not a new draft.
I think you are right. I did not bother to read about what that little eyeball did, I just poked it a few times.
