Hello all,
Anytime I have travel expenses at work, I append the information to a set draft using an action. Then each month or so, I send the list via email using another action. Typically I will open the draft for review, then I look for the action to send the email and I’m set.
In order to not look every time for this last action, I included a URL scheme to run it directly from the draft. The action launches fine, but the email does not include the body of the draft as intended, that part is empty. Anyone would know how to resolve this?
The text template from the mail action looks like this:
Bonjour,
<br><br>
Voici mon kilométrage facturable en date du [[date|%Y-%m-%d]] : <br>
<br>
%%[[body]]%%
<br>
Merci,
And the URL to run the action: drafts://x-callback-url/runAction?action=Mail%20km
I don’t include a text argument in the url, although according to the DraftsGuide it would be required.
Thank you in advance for your help!
